Speedy_Pete
Just spent quite a while down in the garage trying to get the drivers side door to line up, wihtout success. I have got the spaces around the door all straight, so it's sitting right, but the lock and striker plate won't line up as the door shuts. From what I can see, the striker plate needs to come down another 1mm but it is as low as it will go. I was going to bring the lock plate up to compensate, but the bolts are not attached to moveable backplates. If I bring the door up another 1mm the front upper part will rub on the A pillar as it opens. Any suggestions?
Hi Guest!
