Morris said:
I did not resize my rods. My final bearing clearances where in the .002 to .003 range.
That could be your problem, thats too uch for a street engine. Let me tell you a story about rod bearing clearence on the A-series engines that will shed some light on this, and maybe help you. Since I started doing this Spridget racing stuff, years ago, I always was told by the Spridget race engine building legends, .002" was the was the bestnumber to be used for rod clearences. A few years ago, I was contracted by a couple of guys to build them a race prepped 1275 bottom end, they suppiled me with thier specs, the only thing out of the norma was they requested .0025" rod clearence, I questioned them on tis, and they said that is what they wanted. Now this guy had netted tow SCCA championships, so who was I to question them right, so .0025" it was. I was building myslef a new 1275 race engine at the same time, ad decided I would use this same recipe. WEll the engine ran fine, but for the first time in my career I was fighting oil pressure problems, I end up over regulating the crap out out of the prssure regulator to get cold pressure up, that helped a bit, but not as much as I waned. I was always use to 80+ Psi cold and 70 psi hot after a 18 lap national race, with this motor I was lucky to be 60 psi cold, and 40-50 psi hot at the end of the race. While everything ran alright and the motor was fast, if you let the engine go anywhere near a idle coming into to impound the pressure would drop to near nothing, that made me fell uncomfortable. When I quit racing SCCA, Iended up selling the motor to friend of mine, and decided to repalce the crank and size everyhting back to .002", well guess what the oil pressure wnet right back to the 80 cold and 70 hot like I was used to, tuen out my buddies in Texas ended up having the sameissues I did with the .0025, and when they heard what I had done went back to a .002" set up and saw the same improvements I had.
Here's the deal, as little as.0005-.001" too uch clearence on the rod in a A-series engine can let too much oil bleed off the at the rods, and make the engine struggle harder to mantain oil pressure. NOw in our case we got the extra clearence at the cranshaft journal, so our fix required new cranks, but yor problem is more than likely waer to the housing bore (big end) of the connecting rods. Bottom line I will not build a engine without sizing the rods, you may get lucky, but the odds are you will not. What I see sizing A-series rods as with most connecting rods, that over time they will grow at the parting line, and this will increase clearence, as well as not securely hold the bearing. Resizing rod is relatively cheap, so do ing it along with replacing rod bolts I feel are a necessity when rebuilding one of these engines, it the key to having good oil pressure in my opinion. In race engine you always have mre clearence than you would in a street engine, I buil my street A-series motor on rods and main at .0015".
