tony barnhill said:Problem I've found using rattle can primer is that it sometimes isn't "hot" enough for the paint....& I don't mean temperature.
Swamp_Fox said:Tony, what would you recommend to hold me over till warmer weather arrives ? John, if I put wd-40 on it what would you use to remove it later on. Thanks for all the help. This is all uncharted territory for me, but I enjoy it and am learning alot![]()
