[ QUOTE ]
But today the new spring had actually compressed somewhat in just one day. Perhaps, they just aren't as good a grade. Anyway, I used Dave Russell's idea and shimmed it a little, and the pressure came back up to yesterday's level. Oh, the magnet pulled the relief valve right out, so I was able to clean that as well.
[/ QUOTE ]
A lot of springs are poor quality. A good properly tempered coil spring will maintain it's design length for a long time. A poor spring will take a set the first few times that it is compressed. An easy check is to measure the spring length, compress it in a vice until all of the coils are just lightly touching (coil bind) or nearly touching & let it set for a couple of hours. Remove the spring & measure it's length again. If there is significant shortening, the spring is low quality & will not maintain it's design tension. Throw it aside & look for a better spring. Any spring will fatigue a bit over time & loose some of it's tension, but it should take years, not one compression, to lose tension. If the spring has gotten shorter, taken a set, once it has taken a set it will usually remain at it's new shorter length for quite a while. Sometimes something can be adjusted to compensate for the loss of length, such as a shim, & it will last quite a while at its new set length. Some triumphs & such have adjustable spring stops to adjust for loss of spring tension to adjust oil pressure. Same idea for putting spacers under sagged coil springs.
