TRMark
I was going to do some rear seal work to cure a nasty leak. Then I looked at the camshaft.
So apart comes the engine. While I have it apart............
I was Road America last September and talked to the TR4 racers about keeping the engine together if I installed a more aggressive cam and wanted to use higher RPM. I was kinda surprised to find out the guys I talked to were using a very "carefully prepared" stock crankshaft along with Carrillo rods. Thought I would hear Carrillo and "Moldex" or some other custom billet crank. The Carrillo rods are doable but I am not sure what is meant by "carefully prepared." Any suggestion as to what that means and/or where I can send the crankshaft.
