SherpaPilot
My 53 year old fuel tank in my TR6 developed corrosion which contaminated my fuel system. The fuel pump, fuel lines and carburetor float valves were replaced. I also decided to replace the original tank with a new one, new sender and associated hardware. The tank was removed quite easily. The new one is expected to arrive almost any day. I feel I need to make certain no small foreign material is in the new tank from manufacturing. What is the best way to flush out the new tank without leaving small droplets of water remaining after the flush. I have been considering an alcohol mixture. Has anyone installed a new tank in their car and if so, did you flush it out with anything prior to the install? This is my first time doing this job. Thanks for any input.
