Stewart
The engine on my B has been removed from the car for paint and body work and since it's out and its going to be torn down somewhat to change gaskets in an attempt to slow the leaks and check the condition of the engine internals. If everything checks out ok I wouldn't mind spending the bucks now when everything is apart and can be matched together.
What would your suggestions be for engine mods that are reasonable on the wallet and reliable for the street? Carb and manifolds will be replaced and hopefully the ZS will have a long retirement in the garage.
Engine is from a 75 with 46k miles on it.
