[ QUOTE ]
In his "How to Power Tune MGB 4 Cylinder Engines", Peter Burgess gives many recipes for increasing bhp. Some are simple (use K&N filters over WalMart varieties), others way complex and expensive (a crossflow cylinder head - a cool $800). Hey - you can even add the Moss supercharger for only $3000! Burgess also gives seven areas which can be tweaked (or sledge hammered ...) to gain power.
1. cylinder head modification
2. air filters
3. camshaft mods
4. exhaust mods
5. ignition system
6. carburetion
7. dyno tuning
and I would add #8 - weight reduction
I'm looking to add a bit of road bhp - not for racing or sprints, just for keeping pace with those semi's on the Interstates.
Which areas do forum members actually implement?
Was this discussed in an earlier forum thread?
Newbie Tom
(rated 99.44% free of avatars and gremlins)
[/ QUOTE ]
Hi Tom,
I'm sure that Burgess must have stressed that the engine is a system of parts which must all be coordinated together when modified. To get maximum benefit, they must all be implemented.
Not a whole lot can be gained without modifying the cylinder head first. Larger ports are not necessarily better. The shape of the ports & areas on both sides of the valve seats are most important. This needs to be determined by someone with experience on your particular engine. I haven't seen the Burgess book. Maybe he gives port shape & size information. Port velocity in the right places is far more important than sheer port size. In fact over porting can turn an engine into a real dog.
Air filters can help a little. Better exhaust can help a little. Cams can help a little or hurt a lot. Carburetion can help a little. Better ignition will help if the other modifications cause a need for it. Dyno tuning will only help a little if fuel mixtures & ignition timing are quite a bit off. It is a good way to find out where you're at after a series of modifications.
With a coordinated set of modifications, the whole combination will help a lot. These benefits can only be realized if the engine is in top mechanical condition to start with. In fact, the engine will not stay together long if it isn't mechanically up to the added stresses imposed by the power increases.
All of these modifications, with the exception of higher compression, or supercharging, will move the power band higher in the rev range & reduce low rpm torque somewhat.
Sometimes, simply a good overhaul of a worn engine, can increase power to a very noticeable extent. This would be the time to increase compression ratio by using higher compression pistons instead of milling the head which can create it's own set of problems.
I'll leave it up to those with "real experience" on your particular engine to give further advice on specific details. I'm sure you will get some good responses. However you can't violate the above principals very much & have real success.
