RJS
Hi All,
Not being an electrical expert, looking for some advice to connection spot for power (+).
First one is a connection for headlight power. I have recently installed relays and presently have the power (+) lead connected directly off the battery (+) terminal. Is this OK or is there a preferable spot off the fuse box? If so, which terminal? This connection does not need to be switched with ignition power.
Second, I have new headlights with a city light option. I am using the city light feature as a DRL for safety. This one needs to be switched with the ignition. Presently it is wired to the (+) terminal on my ignition coil. I suspect this is not ideal. Other ideas/suggestions?
Thanks
Bob
PS: later I am planning on installing a USB power supply descretely under the dash. Will likely want to power this same as my city lights
Thanks
Bob
