Power for electric fuel pump
The fuse block would be my choice. Find a circuit that is only hot with the ignition on.
Some people run the power from the coil + terminal. Wherever you decide, install an in line fuse in the system.
Jeff
I ran to the fuse block, I can take a picture and post it here this morning.
I ran to ign, switch.
It's the white wire with the yellow end.
