David_Doan
So, I was working on this little spreadsheet for my wiring diagram, to see how much draw each circuit would have. The table below (which amazingly just pasted in from excel) shows what I found so far. In each case if I found varying results, I just used the worst case.
Wipers, Heater, and Ignition are unknown. Wipers I will test when I put mine back together. Anyone have any idea what the average draw for the points ignition is? After a lot of googling, I found nothing.
[TABLE="class: grid, width: 387, align: left"]
[TR]
[TD]Component[/TD]
[TD]Watt[/TD]
[TD]Amps[/TD]
[TD]Number[/TD]
[TD]Total Draw[/TD]
[/TR]
[TR]
[TD]High Beam[/TD]
[TD]65[/TD]
[TD]5.4[/TD]
[TD]2[/TD]
[TD]10.8[/TD]
[/TR]
[TR]
[TD]Low Beam[/TD]
[TD]55[/TD]
[TD]4.6[/TD]
[TD]2[/TD]
[TD]9.2[/TD]
[/TR]
[TR]
[TD]Brake Lights[/TD]
[TD]21[/TD]
[TD]1.8[/TD]
[TD]2[/TD]
[TD]3.5[/TD]
[/TR]
[TR]
[TD]Tail/Parking Lights[/TD]
[TD]5[/TD]
[TD]0.4[/TD]
[TD]4[/TD]
[TD]1.7[/TD]
[/TR]
[TR]
[TD]Flashers[/TD]
[TD]21[/TD]
[TD]1.8[/TD]
[TD]2[/TD]
[TD]3.5[/TD]
[/TR]
[TR]
[TD]Wipers[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]0.0[/TD]
[/TR]
[TR]
[TD]Heater[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]0.0[/TD]
[/TR]
[TR]
[TD]Dash Lights[/TD]
[TD]2.2[/TD]
[TD]0.2[/TD]
[TD]6[/TD]
[TD]1.1[/TD]
[/TR]
[TR]
[TD]Ignition[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]0.0[/TD]
[/TR]
[TR]
[TD]Fuel Pump[/TD]
[TD][/TD]
[TD]4.5[/TD]
[TD]1[/TD]
[TD]4.5[/TD]
[/TR]
[TR]
[TD]License Plate[/TD]
[TD]6[/TD]
[TD]0.5[/TD]
[TD]1[/TD]
[TD]0.5[/TD]
[/TR]
[/TABLE]
(Fuel pump is a Carter P60504)
[TR]
[TD]Component[/TD]
[TD]Watt[/TD]
[TD]Amps[/TD]
[TD]Number[/TD]
[TD]Total Draw[/TD]
[/TR]
[TR]
[TD]High Beam[/TD]
[TD]65[/TD]
[TD]5.4[/TD]
[TD]2[/TD]
[TD]10.8[/TD]
[/TR]
[TR]
[TD]Low Beam[/TD]
[TD]55[/TD]
[TD]4.6[/TD]
[TD]2[/TD]
[TD]9.2[/TD]
[/TR]
[TR]
[TD]21[/TD]
[TD]1.8[/TD]
[TD]2[/TD]
[TD]3.5[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]0.4[/TD]
[TD]4[/TD]
[TD]1.7[/TD]
[/TR]
[TR]
[TD]Flashers[/TD]
[TD]21[/TD]
[TD]1.8[/TD]
[TD]2[/TD]
[TD]3.5[/TD]
[/TR]
[TR]
[TD]Wipers[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]0.0[/TD]
[/TR]
[TR]
[TD]Heater[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]0.0[/TD]
[/TR]
[TR]
[TD]2.2[/TD]
[TD]0.2[/TD]
[TD]6[/TD]
[TD]1.1[/TD]
[/TR]
[TR]
[TD]Ignition[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD]0.0[/TD]
[/TR]
[TR]
[TD]Fuel Pump[/TD]
[TD][/TD]
[TD]4.5[/TD]
[TD]1[/TD]
[TD]4.5[/TD]
[/TR]
[TR]
[TD]6[/TD]
[TD]0.5[/TD]
[TD]1[/TD]
[TD]0.5[/TD]
[/TR]
[/TABLE]
