Gblake2613
thought maybe some of you could answer the steering question/maybe brake too...
"I am starting to think about my brake system on my TR3. I want to use a dual circuit and I have been looking at the overhung pedal assemblies offered by Tilton in the Pegasus and Speedway catalogs. Has anyone used one? Which ratio are you using 5.5 or 6.2? Has anyone tried making their own dual m/c bake setup using the original TR pedal box? How difficult was it?
When using a dual circuit, how do you select the size for the m/c bores?
I assume that when you switch to a dual circuit the 5 way with the restrictor on the lower front frame rail is no longer required, is this correct?
On more question for today. What is the correct size splinned coupler for the input to the steering rack? When I miked it, it looked like it would need to be a 36 spline 5/8" diameter. I can not find this size coupler anywhere. Should it be a 9/16"-36 spline? I don't have the original TR couplers (that are no longer available) since this is a TR3 going on a TR4 frame and I did not get a complete steering assembly from my donor frame.
Thanks,
Greg"
Thanks,
Greg"
