Hi Guest!
Please don't turn this into another diatribe like the silicone brake fluid thread.Bob_Spidell said:WRT to replacement/NAPA parts, if you do any serious cross-country driving you should carry spares for the items mentioned anyway. If you're 100+ miles from the nearest NAPA/Kragen/AutoZone/etc. it doesn't matter if you're positive or negative ground.
Randy Forbes said:Please don't turn this into another diatribe like the silicone brake fluid thread.Bob_Spidell said:WRT to replacement/NAPA parts, if you do any serious cross-country driving you should carry spares for the items mentioned anyway. If you're 100+ miles from the nearest NAPA/Kragen/AutoZone/etc. it doesn't matter if you're positive or negative ground.
The topic is, if the original poster should convert his car to negative ground, and I merely stated an example in favor of it.
It was not my intention to provoke another argument from you, nor will I participate in one.
Scott is lucky, he got one of them older Healeys with the mechanical tach.tahoe healey said:the tack loop needs to be reversed.
There are a couple threads here in the archives. Oh, Jim Werner's site was closed by AOL (nothing he did, they did it to a whole lotta people without much if any warning). John Sims was able to salvage almost all of it and that info is now on John's site. https://www.healey6.com/tahoe healey said:The whole thing takes 20 minutes and costs you nothing. I think there was a "made simple" on Jim Werner sight. Also on the MG sight. I have the references some where in my files if any one is interested. There is probably one in the BCF archives.
tahoe healey said:He means changing the connections not the type coil.
