EEtinkerer
To all car nuts out there,
I have been totally stumped by this vehicle for quite some time. I have rebuilt several other old cars including a full restoration on a 1956 Chevrolet Bel Air that is a fairly hot street setup. Anyways, my 1974 TR6 is driving me completely nuts and no one that I speak to has any idea what is going on.
The car was purchased two years ago from a guy who installed a new cam, three 40DCOE weber carbs, rebuilt the frame and drivetrain and had it set up for club racing. Well I ended up going off to college with little time to play with this vehicle so it sat in the garage for awhile.
Coming home to work on it the car would never want to idle. It sounded almost like a two stroke with just terrible idle characteristics so I took the carbs off and rebuilt them all. Then I set them all back to the factory recommended tuning settings and it still ran poorly. Replaced the points, condenser, cap, rotor, wires, plugs and still stuck with the same problem.
I went back to school and it has been a year since I've been under the hood because it just doesnt want to run. Well, I started it up and it still runs horribly but something new came up. On a trailing throttle, there is a terrible squealing noise coming from the front of the engine. I disconnected the belt from the water pump and the squeal still occurs. I took the rocker arm cover off and adjusted the valve lash while I checked to confirm that all the rockers were getting properly oiled (and they were.) The oil pressure gauge works intermittently but has at least 50lbs cold pressure so the oil pump isnt dead. The engine only has about 5k miles on it since the guy rebuilt everything and we inherited it. I need to figure out what this horrible squealing noise could be. Even marvel mystery oil didnt ferret it out.
The poor engine running problem has driven me up the wall as well. I've rebuilt the carbs and soaked the parts in carb clean for 24 hours each and that seemed to help but that was over a year ago. The engine sputters and backfires terribly. At 3000rpms, the engine smoothes out and runs great. I've tried top end cleaners like Sea Foam and it just makes a large amount of smoke with no apparent running improvement. The engine doesnt idle and will absolutely not run at part throttle. I have to goose the throttle to keep it running. A slight tip-in condition will cause a stall condition so it's just stab throttle that will keep it running. I have tried turning the distributor static and while running and it doesnt seem to make enough of a difference. I also can't get it running well enough to check the timing with a timing light!
Any advice on ANY of these problems would be greatly greatly appreciated. I have never been so distraught or completely confused by a car. I hope someone here has an idea! Thanks in advance.
Hi Guest!
