Randy Forbes
Having a little time in between jobs (not really, but I haven't yet told the next guy that the last car's done...) I was able to spend the entire day today playing with pistons.
Two (2) sets; 100/6 +.040" & 3000 +.060".
The +.060" set needed a few thousandths build up on the skirts (w/TLMB), which is then top-coated with a dry-film lubricant (TLML).
Both sets had their crowns coated with a thermal barrier; well, eleven (11) out of twelve (12) isn't bad...
Masking prior to blasting:
After blasting w/aluminum-oxide:
Skirts built up on +.060" set, and masking pin bores:
All coatings applied, and ready to be cured:
Post cure:
Rhuh-rhoh (naturally, it's a +.060" piston)...:
Chart:
More pictures @: https://www.rfdm.com/gallery/album223
Post cure:
Chart:
