Couple of questions on drain plug sizes. On a smooth case transmission (at least mine) the drain plug and the fill/check plug seem to be the same size. I used a 3/4" socket, as it seemed to fit the best, but seemed a bit loose. What size is this really?
On a related note, the rear diff has 2 recessed square drive plugs. What size are these? I need to D&R the rear as well, and don't seem to have the right size square drive. Seems larger than 3/8", smaller than 1/2".
