trrdster2000
It must be that time of year for plastic lines to blow (Dale's clutch line). I can blame mine on the contorted position you have to get in to change the oil filter. I must have hit the very end of it and it broke right at the fitting. I have done this on TR's for many years, so you don't have to be a novice to make mistakes. I do know to put an oil pan under the car to check for leaks on the canister, but that tiny little line blew oil all over the place, no leaks in the canister, Hoo-ray. My question is " 1. Do I heat the end of this hose and slide it back on? or 2. Go to the local plumbing store and get a presure fitting of the right size and correct threads?
I know all of the new oil presure gauges have this type fitting but ours has the bubble fitting on the end but it looks like enough depth in the threads to take this type of fitting.
If I get no replys, it will make me fill all the more dumb, come on guys, surely someone has done this or helped someone who has.
Oh, next thing on the list of to buy is the conversion oil filter spin on arrangement.
Thanks Wayne
Thanks Wayne
