TR4/4A Placement of OD relay
Twit
Member
I've added overdrive to my early TR4 (2292) and am trying to figure out the correct placement of the relay. I've located 2 rubber plugs that appear to have the correct spacing to mount the relay and figure that is the spot but I'm looking for confirmation as I am trying to do everything correctly. Does anyone know for sure?
thanks Dave
It usually goes on the inside left of the passenger footwell, just on the other side of the panel from the place where you have it now located. Of course, as long as it is wired right, it will work, regardless of where you mount it.
so the holes are correct but I've got it on the inside of the engine bay whereas it should be inside the footwell?
Yes location is good but inside the footwell instead
