Pixel primmer size, well I put another coat of primmer on the hood because the epoxy was starting to come through and there some scratches. I must have had the pattern set too high or the temp was too low or no reducer….. Anyways I sanded it off and still had problems with scratches and I cut deep again. So this time I am going to use some reducer and wet sand.
The guy at the paint store suggested wet sanding with 400. My question is should I use only 400 or start with 220 and work down to 400 when wet sanding.
