Hi Mike,
Some folks choose to have their liners bored out. It is certainly possible. But it might not be very cost effective. The cost to have the machining work done, plus purchase a set of pistons, is about the same as some new sets of matched liners and pistons (usually including wrist pins, rings and figure 8 gaskets).
One concern with old liners is that they will likely have some effects of corrosion on the outside, which will probably reduce their efficiency exchanging heat with the coolant. There is also a possible concern that a liner has a hidden crack or other weakness.
Still, boring is an option. It's your choice and your car, after all! Someone who has access and skills to do the machine work themselves - or a buddy with a machine shop who might do it in exchange for a pizza and 6-pack - might find re-boring the old liners the more cost effective route.
Before seeking out a supplier, decide which piston you prefer.
The original pistons were AE Hepolite, but are next to impossible to find in any size.
AE Powermax are uncommon, too, but good pistons if you can find them, although the rings provided with them are very slow to bed in. The full set piston and liners are generally very well matched and seldom need any balancing or deck height adjustment. I can't say, though, if you can get the pistons alone. I've got a piston/liner set that are going to be installed in my car. I had pretty well decided to use the "hard" rings that came with it, since this is a street car and I figure they will give longer service than fast-bedding "racing" rings. But, I keep going back and forth with myself on this issue and still might switch to a set of Deves rings. The harder rings might be harder on the cylinder bore, too.
Mahle is a more commonly available piston brand and seem to be pretty good.
JE Pistons make some forged pistons for TRs, I'm not sure about 87mm/standard height though. I think they supply the "stroker" pistons to Cambridge motorsport, to be used with special, longer con rods. Expect these pistons to be more expensive. But, chances are JE can supply other types and sizes, too. I found a website for them, but don't have the link now.
If you do some searching, you'll not only find 87mm, but also 87.5mm, 88.5mm and 89mm which can be fitted without making any changes to the TR 4-cylinder block. Do note that 88 to 89mm require a stronger alloy liner, because it's relatively thin. Even 92mm are available, but need the block machined to accept the larger liners.
A larger bore piston will reduce compression slightly. It's possible to mill the head to compensate, if you wish.
One good and very knowlegeable source is Ken Gillanders at British Frame and Engine (
www.britishframeandengine.com). He's an engineer and a walking encyclopedia of 4-cylinder TR info, has been building performance Triumph engines and racing TRs for something close to 50 years. He knows very well what works and what doesn't and can give you good advice. Ken's focus is on performance parts. He supplies a lot of things that simply can't be found elsewhere.
British Parts Northwest is another source. They offer 87mm pistons separately, but don't say what brand.
www.bpnorthwest.com is their website.
Cheers!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
