Pinion Seal Replacement
svtmikey
Probably an easy question.
Can you replace the pinion oil seals while the differential is still in the chassis or do you have to remove it?
Thanks
Remove the driveshaft and flange. Remove and replace the seal...torque the flange to spec and you are done.
