Pilot - Control Tower
Shane
<span style="font-style: italic">This is an oldie but a goodie, tried searching but haven't seen it posted here:</span>
Actual exchanges between pilots and control towers
Tower: "Delta 351, you have traffic at 10 o’clock, 6 miles!"
Delta 351: "Give us another hint! We have digital watches!"
Tower: "TWA 2341, for noise abatement turn right 45 Degrees."
TWA 2341: "Center, we are at 35,000 feet. How much noise can we make up here?"
Tower: "Sir, have you ever heard the noise a 747 makes when it hits a 727?"
From an unknown aircraft waiting in a very long takeoff queue: "I'm (bleeping) bored!"
Ground Traffic Control: "Last aircraft transmitting, identify yourself immediately!"
Unknown aircraft: "I said I was (bleeping) bored, not (bleeping) stupid!"
O'Hare Approach Control to a 747: "United 329 heavy, your traffic is a Fokker, one o'clock , three miles, Eastbound."
United 329: "Approach, I’ve always wanted to say this…I’ve got the little Fokker in sight."
A student became lost during a solo cross-country flight. While attempting to locate the aircraft on radar, ATC asked, "What was your last known position?"
Student: "When I was number one for takeoff."
A DC-10 had come in a little hot and thus had an exceedingly long roll out after touching down.
San Jose Tower Noted: "American 751, make a hard right turn at the end of the runway, if you are able. If you are not able, take the Guadeloupe exit off Highway 101, make a right at the lights and return
to the airport."
A Pan Am 727 flight, waiting for start clearance in Munich , overheard the following:
Lufthansa (in German): " Ground, what is our start clearance time?"
Ground (in English): "If you want an answer you must speak in English."
Lufthansa (in English): "I am a German, flying a German airplane, in Germany .
Why must I speak English?"
Unknown voice from another plane (in a beautiful British
accent): "Because you lost the bloody war!"
Tower: "Eastern 702, cleared for takeoff, contact Departure on frequency 124.7"
Eastern 702: "Tower, Eastern 702 switching to Departure.
By the way, after we lifted off we saw some kind of dead animal on the far end of the runway."
Tower: “Continental 635, cleared for takeoff behind Eastern 702, contact Departure on frequency 124.7. Did you copy that report from Eastern 702?"
BR Continental 635: "Continental 635 cleared for takeoff, roger; and yes, we copied Eastern...
we've already notified our caterers."
One day the pilot of a Cherokee 180 was told by the tower to hold short of the active runway while a DC-8 landed. The DC-8 landed, rolled out, turned around, and taxied back past the Cherokee. Some quick-witted comedian in the DC-8 crew got on the radio and said, "What a cute little plane. Did you make it all by yourself?"
The Cherokee pilot, not about to let the insult go by, came back with a real zinger: "I made it out of DC-8 parts. Another landing like yours and I'll have enough parts for another one."
The German air controllers at Frankfurt Airport are renowned as a short-tempered lot. They not only expect one to know one's gate parking location, but how to get there without any assistance from them. So it was with some amusement that we (a Pan Am 747) listened to the following exchange between Frankfurt ground control and a British Airways 747, call sign Speedbird 206.
Speedbird 206: “Frankfurt, Speedbird 206! Clear of active runway."
Ground: "Speedbird 206. Taxi to gate Alpha One-Seven."
The BA 747 pulled onto the main taxiway and slowed to a stop.
Ground: "Speedbird, do you not know where you are going?"
Speedbird 206: "Stand by, Ground, I'm looking up our gate location now!”
Ground (with quite arrogant impatience): "Speedbird 206, have you not been to Frankfurt before?"
Speedbird 206 (coolly): "Yes, twice in 1944, but it was dark…and I didn't land."
While taxiing at London 's Gatwick Airport , the crew of a US Air flight departing for Ft. Lauderdale made a wrong turn and came nose to nose with a United 727. An irate female ground controller lashed out at the US Air crew, screaming: "US Air 2771, where the heck are you going? I told you to turn right onto Charlie taxiway! You turned right on Delta! Stop right there. I know it's difficult for you to tell the
difference between C and D, but get it right!"
Continuing her rage to the embarrassed crew, she was now shouting hysterically: "God! Now you've screwed everything up! It'll take forever to sort this out! You stay right there and don't move till I tell you to! You can expect progressive taxi instructions in about half an hour, and I want you to go exactly where I tell you, when I tell you, and how I tell you! You got that, US Air 2771?"
"Yes, ma'am," the humbled crew responded.
Naturally, the ground control communications frequency fell terribly silent after the verbal bashing of US Air 2771. Nobody wanted to chance engaging the irate ground controller in her current state of mind. Tension in every cockpit out around Gatwick was definitely running high.
Just then an unknown pilot broke the silence and keyed his microphone, asking:
"Wasn't I married to you once?"
__________________
:lol:
Those definately showed their age but were a scream anyway.
I like the one about the rural airline that is making it's first flight into O'Hare. On approach, the pilot is contacting the tower:
Flight 721: Tower, where do you want us to land?
Tower: Runway 347.
Flight 721: Tower, runway 347, are you sure?
Tower: Yes, Flight 721.
Conversation on cockpit recorder:
Pilot: Ok, when the tires touch, hit FULL reverse, FULL brakes, and throw out an anchor if you have to!
Co-pilot: Roger.
<a few minutes later, sounds of reverse thrusters, brakes, tires squealing, paniced breathing by Pilot & Co-pilot>
Pilot: Man, that must be the SHORTEST runway we've EVER landed on!!
Co-Pilot: YEAH, but would you look at how WIDE it is?!!!
*SWOON*
<THUD!>
Another one I like is two blind pilots board the plane and go to the cockpit. The passengers watch, somewhat stunned as they go through the preflight check. Then they start to taxi and line up on the runway. They release the brakes and run up the throttles. The plane moves forward, building speed and getting closer and closer to the end of the runway. Finally a collective scream runs through the plane and it lifts off and climbs into the air.
One pilot says to the other: "One of these days they're not going to scream!"
"Braille Pilots!"
:lol:
His request approved, the Fox News photographer quickly used a cell phone to call the local airport to charter a flight. He was told a twin engine plane would be waiting for him at the airport.
Arriving at the airfield, he spotted a plane warming up outside a hanger. He jumped in with his bag, slammed the door shut, and shouted, 'Let's go'.
The pilot taxied out, swung the plane into the wind and took off. Once in the air, the photographer instructed the pilot, 'Fly over the valley and make low passes so I can take pictures of the fires on the hillsides.'
'Why?' asked the pilot.
'Because I'm a photographer for Fox Cable News,' he responded. 'And I need to get some close up shots.'
The pilot was strangely silent for a moment, finally he stammered,
'So.... er, ....
what you're telling me, is ... um....
you're <span style="font-weight: bold">NOT </span>my flight instructor?'
:lol:
THAT'll run up your laundry bill!
Air Force Tower
Pilot: Tower, what is the local time
Tower: if you are regular Air Force the time is 16:00 Lima, If you are AF Reserve, it's 4 o'clock in the afternoon, if you are AF National Guard, Mickey's little hand is on the 4 .......
Pilot of small plane landing at a small controlled field: Tower, Cessna 7829 Golf would you please call my wife and tell her I've been delayed a few hours due to weather, and I'll call her when I arrive.
Tower: 29 Golf, no problem.
Cessna 29G : Tower, Could you please call my girlfirend and ask her to pick me up in 15 minutes.
While I don't doubt that UAL might have said that, but I know that prhase has been uttered on the ATL airport before.
Delta Mtc 935: Atlanta ground, ready to taxi to ramp 1 from the TOC.
Atlanta Ground: Delta Mtc 935, after the American Fokker, turn left on taxiway echo and continue on to ramp 1
Delta Mtc 935: After the Fokker, turn left, taxiway echo to ramp 1. Got the Fokker in sight. Good night!
How do I know that exchange took place at ATL? I was the smart mouthed radio rider on Delta Mtc 935! :thumbsup:
Steve said:
Hehehehehe!
I see from your sig line that you are a fan of the Lee Enfield..... I assume you must have one?
One??????????????
Try 5 No.1 Mk.3's One Enfield, one BSA, One LSA, one Lithgow, and one Ishapore.
I also have an Ishapore 7.62mm 2A1 floating around in the safe.
ETA: If you think LBC's are a money draining disease, you should see what a C&R License does to the wallet.
