Group statistics
Members:
18
Threads:
1719
4176
Discussions:
3
Photos:
107
Latest posts
Group events
Photography
Piddlin' around with single-source lighting
Platinum
Only subject handy is me.
Used a 50mm ∱1.4, wide open, the light is a Vivitar 285 at ¼ power, reflected from a white umbrella, six feet from subject.
That umbrella has a lot of wrap around to get light on your ear. Or was there a white wall stage right? Regardless, nice lighting.
White wall indeed. I didn't account for the "splash" from it. As I posted, "piddlin' around."
Still learning the sensor sensitivity.
There isn't much if any noise that I can see zooming in. What was the ISO set at?
Down at 200. And that image is cropped and scaled down considerably. I'm impressed with the sensor's capability with tonal range. I've not done any gray scale "tests" but believe sensor capability now achieves parity with film, maybe even surpasses. I'd not be hesitant about quality of images WRT crop-sensors, low light situations with astronomical ISO settings aside.
Coming from you, I appreciate the compliment.
Thank you. As said earlier, still learning the sensor's capabilities.
1/125th, remote (RF) flash trigger and IR shutter release.
Seamless rolled black paper background, all ambient light eliminated.
My guess is you won't see noise until ISO 1600 or higher. I read the 7500 has the same sensor as the D500. So your shot was well within the "comfort zone" of the settings.
Digital passed film at least a decade ago in the 35mm format if you had the cash. I have compared my prints to my 11×14 portfolio. Using the same lenses across media, digital is a lot crisper. 8×10 film still probably holds the crown. Way cheaper to scale a piece of film up.
One of the things great about some of the newer cameras and sensors is their great low-high and high ISO performance. My Canon 6D has phenomenal high ISO performance.
One of the things I did do with the ISO settings was to make 1600 as a "limit" when in the automatic mode.
At that point in time I'd completely ignored the craft, had no desire to keep up with developments WRT digital photo. Likely would have spent a boatload of cash otherwise. Mitsy had a fixed-lens DSLR Fuji, that served for the "happy snaps" and family record pix.
As mentioned before, the tonal range these current sensors can record is impressive. I'm sure I'd need some fill lighting to get the same results as the shot above if using film.
