Picture needed - front turn light
steveg
Hi all - my car's in the body shop and I need a clear picture of the front turn light showing the little circular raised area around where the signal light is mounted. It should be mostly from the side so it shows how far it protrudes from the fender.
Thank you in advance.
Steve,
I don’t have anything from the side as you requested. Don’t know if this is helpful or not:
After looking at some of my pictures it seems to me that the raised surfaces were raised enough to have the light bases on the same plane. Of course that would seem logical. But it also means that the amount of raising of the metal would change as you index around the curved surface of the fender and the shroud. Pic attached:
