Re: St. Louis MGB-GT
Thanks for the good words. My wife really liked the color. It is Mirage. Also, I believe it had Sabrinas. Knowing so little about buying an MG, now that <span style="font-style: italic">they/we </span> are "classics", we thought she might be a good one, to fix up. There is definitely work to be done. There are some bubbles popping up in several places, hood, fender, and some rust along panels below the doors. We had Dave Sanders Imports (Anderson, SC) referred by the BHive, put it on a rack, check underneath, oil change, lube, change some gas lines. He confirmed it looked pretty sound. We thought so, but with the rust starting to show, we had concerns. Engine sounds good, shifts tight, no real play in steering. Needs exhaust pipe and a real close inspection to change whats old and worn. Gas mileage is about 10mpg right now. Charley said he put a brand new MGB engine in it around 2000. He drove it to shows and used it in some rallys. Also did alot of sheet metal work and restored the original paint color.
Any suggestions? Rust, mechanical, etc. Also, restoring the original color Mirage, and good shops for body and mechanical work in No Alabama/So Tennessee?
