I just put the Petronix flame thrower coil on my TR3 about March 10, 2016. It has failed. I had installed the Petronix ignitor about 2 years ago and no problems with that. I was getting no spark to the plugs. On the Flame-thrower I measured the ohms between the + and - terminals and that was 3.5. Then I measured the ohms between the center post and the + terminal and the ohm meter didn't move. Also nothing between center post and - terminal. The label on the coil looks good as new so it did not get too hot. So I put the original coil back on. In re-installing the old coil, since the car is negative ground, I connected the power wire from the battery and the red wire from the Pertronix ignitor to the SW pole on the coil, and connected the black wire from the Pertronix ignitor to the CB pole on the coil. I now have to decide if I stay with the old coil or get a replacement Pertronix Flame-thrower coil.
Regards, Bob
Regards, Bob
