twas_brillig
E-mail from Pete Delaney, received April 27, 2010, outlining what is in his/Smitty's 5 speed kit for installing a Toyota transmission and the cost of the kit.
I live in Calgary, Alberta, Canada so presumably the shipping that is included in the $ 1975 US is to my location. His contact info is at the end.
For more detail (including photos and advice) find "Healey 5 speed conversion" originated by BlueRidge1 2010-04-20.
Doug
Here is the information you requested for the conversion kit.
Kit Includes:
1 Bell Housing
1 Clutch Disc
1 Pilot Bearing & Adaptor
1 Transmission Mounting Plate
1 Speedometer Cable
1 Clutch Alignment tool
4 8mm x 1” bolts
4 5/16” x 1” bolts
2 3/8” x 1 ¼” bolts
1 Clutch Slave Rod
1 Manual
Drive shaft – New and balanced
New Toyota Parts
1 Release Bearing
1 Clutch Arm
1 Speedo Angle Adapter
1 Speedo Gear
1 Sleeve Subassembly Speedo
1 Clutch Release Boot
1 Trans Rubber Mount
1 Pivot Bolt
In order to convert to a forward shift tower these new parts are used:
1 Forward shift tower
1 Housing Shift
1 Bushing for shifter
1 Shifter Cap
1 Shifter Spring
1 Baffle Extension
1 Seat for Shifter
1 Chrome Shift Lever
Total $1975 which includes shipping.
The following transmissions can be installed into the Healey with the conversion kit and most are available at any salvage yard:
1) 1982-86 Toyota Supra 5 speed transmission
NON Turbo Toyota Supra '86-'90
2)1991-2004 Toyota Pickup 2 wheel drive ONLY, 5 speed transmission. Truck transmissions are the most available up thru the 2004 Tacoma.
The early models of course have higher mileage. Transmissions are usually good from any salvage yard.
Thanks for your inquiry and let us know if you have any questions.
Happy Healeying,
Stephanie & Pete Delaney
Healey 5 Speed
P O Box 561
Harrisburg, NC 28075
704-455-2585
704-455-8504 FAX
Healey5Speedaol.com
Doug
Kit Includes:
1 Bell Housing
1 Clutch Disc
1 Speedometer Cable
4 8mm x 1” bolts
4 5/16” x 1” bolts
2 3/8” x 1 ¼” bolts
1 Clutch Slave Rod
1 Manual
New Toyota Parts
1 Release Bearing
1 Clutch Arm
1 Speedo Gear
1 Pivot Bolt
1 Housing Shift
1 Shifter Cap
1 Shifter Spring
1 Baffle Extension
1 Seat for Shifter
Happy Healeying,
Healey 5 Speed
P O Box 561
704-455-2585
704-455-8504 FAX
Healey5Speedaol.com
