TR2/3/3A Pedal box Tr3
Tr3aguy
OK so somehow the bolts that hold the pedal box together are missing.....anybody know the size and thread of these? I am speaking about the one that hold the pedals to the assembly.....just to be clear.
Aloha,
the bolt is 3/8" UNF x 5/8" long. The Standard Triumph part # is HU0905 and is listed as a set screw. The bolts should be fitted with a lock washer.
From what I remember, they were a bit "odd". I think the heads were abnormally large for the size of the threads, to give a larger bearing surface.
John
Nope. Only thing odd about these is the length. Generally the hardware store only carries increments of 1/4", but you can cut down a 3/4" to fit.
Note that there is a "magic decoder ring" for all the part numbers that begin with two letters, available for download at:
https://docs.google.com/open?id=0B2H2NJt34OffMjJhY2YwZmQtYzgxNC00ZTk0LTk1YTUtZTIyZmU3ZTc1Y2M4
