SherpaPilot
I have been chasing a brake fluid leak in my 72 TR6. Fluid is seeping from the PDWA nylon switch and running down the frame. After purchasing a new switch, checking alignment of the internal piston and reinstalling, it continues to leak. I attempted to try a rubber "o" ring but that was a waste of time as it continued to leak. The leak is passing by the plastic threads and exiting near the top of the PDWA. I am guessing my next step is to remove the assembly and rebuild the entire unit. My question is this: I know I'm not the first person to experience this problem. Has anyone bypassed this poorly designed component in the hydraulic system? Could I simply install a brass plug and eliminate the electrical switch completely? Thanks in advance for any help you can offer. Yes, I have read most of the articles posted concerning rebuilding the switch but I'm thinking of removing it completely.
