I'm in the process of putting a parts order together to finish up the rear end on the Tunebug. I'm switching over to the later backing plates (making the switch to disc brakes up front) using disc parts and rear brake parts from a 74 Midget. I've already got the new bearings and seals for the hubs, just need all the brake bits and gasket for the diff.
Here's my list. Any thoughts? What am I missing?
8@ 265-540 Stud, disc wheels
2@ 180-385 Wheel Cylinder, rear
2@ 326-720 C Clip
2@ 181-760 Boot
1@ 182-175 Brake shoe set
2@ 182-665 Spring, abutment end
1@ 182-670 Spring, RH cylinder end
1@ 182-675 Spring, LH cylinder end
2@ 181-885 Brake drum, rear, premium
4@ 323-255 Screw, brake drum to hub
2@ 294-210 Gasket, differential (I'm including a spare)
1@ 182-248 SS Brake hose set front disc brakes
2@ 326-720 C Clip
2@ 181-760 Boot
