Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
It's usually the backspace that you need to measure. I think 3-1/2" to 3-3/4" is just about perfect although 4" BS would work with spacers on the front to clear. The offset + or - is not the same as backspace. Measure from the rear of the wheel surface where it mounts to the hub to the outer lip of the wheel to get BS.
