[ QUOTE ]
And I don't think using a wobble-head socket is a "bodge".
[/ QUOTE ]
DrE Wrote: "... but if anyone on this forum asked if it were POSSIBLE I'd tell 'em the same as I've stated here for Janel. First go, do it right, THEN you can learn the various bodges."
Th' socket wasn't the issue, James. They're invaluable tools. The pan gasket job with the engine in the car was what I refer to as the bodge. I know it can be done, as stated in the prior post. I'd just never set it as a goal for one who's yet to turn a wrench for more than maintenance/oil changes on an LBC. You or I would likely "just DO it" on our own cars, I've even done it on (cheap) customers' cars. but I can't see sending Janel and/or Chuck down that path. The car would have to be pushing out more than a quart in 1K miles before I'd say they should even fuss with it anyhow. Then it'd be: "Yank it out, reseal it..." ALL of it: Rear crank seal, front, pan, sidecovers... th' lot. Tranny seals at the same time. Much better return on the time & work invested. There'd be a new clutch assembly recommended as well.
