sunkissedhealey
I bought a DVD, The Big Healey Story, from a seller in the UK from eBay UK. It was a 17 minute DVD with some great footage and interviews with the Healey's extended family. Probably copied from a BBC program. The DVD played twice and then it came up with the message: Bad Disc. A few of my more DVD literate friends said that it shouldn't have played on a U.S. DVD player. Well, it did, and twice before it quit. Anyone have any ideas about how to go about converting this PAL DVD so that it is compatable with an NTSC system? Better yet, can it be copied to a VHS? I emailed the seller concerning the BAD DISC response; his reply is below. Thanks in advance for any help.
Rob
THE DVD IS RECORDED IN PAL UK FORMAT IE UK SPEC YOU WILL NEED A PAL DVD PLAYER AND TELEVISION TO VIEW THE SAME HAPPENS HERE IF WE TRY TO PLAY NTSC DVDS WHICH IS THE SYSTEM YOU USE ON OUR TVS THEY DO THE SAME HERE IE BAD DISC BUT IF YOU HAVE TRIED THE DISC ON A PAL SYSTEM MACHINE AND TV AND THE SAME PROBLEM ARRISES THEN RETURN IT AND I WILL EXCHANGE NO PROBLEM BUT THE EXCHANGE WILL BE PAL UK
Rob
Hi Guest!
