nevets
The bonnet of my AH has developed a small bubble in the paint, as though the paint lost its adhesion to the primer. It's not a rust bubble because the underside of the bonnet is perfectly fine. The car was professionally painted with 2-part paint over 10 years ago and the bubble is fairly recent. There are no other defects in the paint anywhere else on the car.
I would like to try to fix it and here is what I thought of so far...
1. Since bubble is flexible, I can actually press it down, so I'm considering using some clay and weights to compress the bubble for an extended period, hoping it will stay down. Possibly apply mild heat from the underside (hair dryer), actually it gets pretty warm with engine heat.
2. Using a hypodermic needle, inject a tiny amount of super glue through the bubble and then press it down until it sets. My fear is that the glue will ooze back up through the needle hole and make a mess or that it will react with the paint and discolor. Too risky.
3. Live with it.
Any other ideas?
Thanks guys.
3. Live with it.
Any other ideas?
Thanks guys.
