[ QUOTE ]
But what ever it is has less power in our two Toyota 4-Runners (at a time we need it most, plowing through the one to two feet of snow we get in an average storm).
[/ QUOTE ]
TH,
I believe that CA is limited to about 10% or less, by volume, of ethanol in the gasoline. This in lieu of the formerly used MTBE. Since ethanol has about 33% less heat content than gasoline, the engine would either run 67% of 10% = about 7% lean or use about 7% more fuel. It depends on how the engine management system is set up on your Toyota. The Healey would just run 7% leaner.
To confound the issue:
If you are at 7,000 ft elevation, air density will decrease about 21% from it's density at sea level, which would make the engine run 21% rich if nothing were compensated. Of course it will also reduce power due to the 21% lesser air available. To confound the issue a bit more, for an intake air temperature drop from 80 degrees F. to 40 degrees F., air density increases about 8% which would make an engine run leaner. The net result for the Healey would be 13% richer mixture for your location in the winter due to combined temperature drop & high elevation. 21% richer in the summer without the temperature drop.
Your other cars should be computer compensated for these changes & show little change except for the 21% loss of power due to high elevation. Their temperature controlled air intake should eliminate the 8% air density change due to temperature change also, as it is likely set to maintain the air temp at about 100 degrees or higher.
With everything factored in, & the fact that the gasoline blend changes with the seasons, I doubt if it is possible to attribute poor engine performance completely to the fuel being used.
