I'm a new Healey owner, having got the car just before winter set in in the Great White North. I am sure there have been threads on overdrive problems before, but I haven't run into the symptoms I have, which are as follows:
Flipping the switch while accelerating produces no noticeable behaviour change, either to speed or revs.
Taking my foot off the accelerator with the overdrive switch on causes the revs to drop...much faster than if I take my foot off with the overdrive switch on. In the second case, the revs reduce slowly, as engine speed is maintained by the inertia of the car. In the first, it is as if I had depressed the clutch pedal. If I touch the gas, I get a lurch, as the car's forward motion is out of sync with the engine speed.
It is as if the overdrive were working like the centrifugal clutch I once had in a Citroen 2CV...I fear for my U-joints as I did then when the engine reengages after losing revs, but the car is still moving quickly.
I had the switch and solenoid checked and the overdrive does seem to engage...you can feel it on the right of the gearbox in the car when it isn't running but the switch is on, but not when it isn't.
Anyone had any experience with these symptoms or can shed any light...my mechanic is poring over his manuals but doesn't yet know where to start.
Thanks,
Canuck
Thanks,
Canuck
