Ok here goes, at work the other day I have a guy bring me an 80 MGB with OD. His problem is that when he is backing up the car makes a ticking that you can feel and hear, similar to a bad U joint or a rear end going out. Both of those checked out ok, and the trans had plenty of fluid. The car only does this when it is backing up when you put it in first and go nothing strange happens and the OD works flawlessly. I have a couple ideas about it but would like some outside imput on the problem as well.
