wkilleffer
After the motherboard in my wife's computer went kaput, I decided to replace it myself.
The new board's an ABIT KW7 VIA KT880 Socket A, which works well with our AMD Athlon processor.
Along with that, I planned to replace the hard drive with a Maxtor 200GB and put a new optical combo drive in as well. The old stuff would go to the Ubuntu Linux box I'm planning to build.
Getting the new board and drives into the case and hooked up was pretty painless. The best part was that everything turned on when I flipped the switch.
The problem is that WinXP won't see more than 137GB of the new drive. The drive is set up with the jumper for Cable Select.
I'm beginning to think that the Maxtor software could be part of the problem. I tried to use it to format the drive first, but it wouldn't work. WinXP will format a drive, so I went ahead and did that. It runs, but doesn't see the whole drive. It doesn't even look like it's seeing the rest as an unformatted partition.
I've run all the updates to get XP up to Service Pack 2 level. Maxtor has a registry patch called Large Drive Enabler, which I installed per its instructions, but that didn't change anything. I've tried booting from the Maxtor disk to do a setup, even if it means reformatting, but it says that there aren't any Maxtor drives on the system.
I'm willing to start over from the beginning if that's what it takes, but it just doesn't seem like the solution will be so radical. I can provide more detail about the setup later if needed. Any ideas or suggestions would be appreciated.
Thank you,
-Bill
Thank you,
-Bill
