Trevor Triumph
I put the engine back in the car with new rings, bearings, seals and gaskets, and a new thermostat, but the same water pump, radiator hoses and such. The temperature gauge registers about a quarter of the travel and stays that way for a while. Then, the needle moves up about mid travel, then a bit higher, and I smell coolant. The coolant line from the radiator fill to the overflow is loose and coolant is gurgling into the overflow tank. The gauge is not pegged, but I don't know what to do. The temperature when it was boiling over was 166 at the thermostat housing, 228 at the inlet and 184 at the outlet. "Help me Obi-wan, you're my only hope!" T.T.
