My '72 B has the proper 25D4 #41491 distributor.
By timing lite measurement it has 42 degrees
internal advance. This gives a beggars choice of
proper initial advance and way-too-much total
advance with piston-wrecking spark knock, OR
way retarded initial advance with good power and
very poor idle, acceleration, and surge at cruise.
Has anyone out there experienced and fixed the
same problem? How about reducing the internal
advance with two heavy advance weight springs?
How about bending the spring posts to make the
advance weights work harder? Who's done the job
and solved the problem?
Thanks in advance for your input.
Cheers,
Doug Noll
Cheers,
Doug Noll
