It's been a heck of a year so far with fuel flow problems.
The latest chapter has the engine dead at 80mph on Toronto's most congested highway. All electrics seem fine, but no "tick-tick" of the fuel pump.
10 minutes of rest, and the fuel pump comes back on and I'm away! The problem however seems to be rapid ticking of the SU pump now.... at idle 60 beats per minute, at road speed 120 - 140 beats per minute and warm to the touch.
The fuel tank full, new gas tank, float level seems fine and no fuel leaking from top of float chamber overflow pipes. High fuel consumption likely due to rich mixture, but I could be wrong.
Based on your experiences can someone provide a list of things to check in order of likely cause?
Does the fuel pump eventually and naturally lose its pumping ability; requiring a more rapid pumping action as it ages (indicating a need to replace)?
Has anyone tried the solid state SU fuel pump that externally looks like the original?
Thanks for your feedback!!!
- Andrew -
- Andrew -
