HerronScott
Marv's radio appears to be a model 4TBTR, which appears in the Sept 64 issue of SAMS Photofact Auto Radio series. That doesn't prove when the radio started being installed in cars, but usually (back then) the AR article was no more than a year after the radio first appeared in cars. (Meaning I think that model probably appeared in late 1963 or early 1964) As noted, it appears to be made by Bendix, but the only indication in the article is that many components have Bendix part numbers. No indication as to country of origin. Somewhere around here I've got a slightly later "Triumph" radio though (5BTRP with the polarity plug), which I believe does carry a "Made in USA" marking somewhere.
Regarding later versions, my 1966 TR4A came with a 6BTR "Triumph" model with polarity switch (see pictures below). Also, I found this document that shows some of the Bendix radios made for Triumphs at least for 1965-1970 (search for Triumph).
https://www.bendixradiofoundation.com/documents/AutoRadio_IllusList.pdf
Scott
