Mark_Gibson
I was able to get the engine on my TR-2 to run today. Needed a carb cleaning, new rotor, cap, wires, plugs and points. It fired up and ran fine. 75 lbs oil pressure at idle cold, 50 lbs at 190 degrees at idle. Smooth, no knocking or any other strange noises. At 3000 RPM there were no noises either. Even the valve train was quiet. The motor has not run in 22 years, so getting it to run after messing with it for 30 minutes is impressive to me. The motor has 56K certified miles on it. I'm doing a frame off restoration, but my initial inclination is to just have the carbs rebuilt, rebuild the water pump, generator, etc, clean and paint the engine and leave it as is. I'm going to put at most 1000 miles a year on this car, and probablly end up putting on a whole lot less. I'm wondering if any of you with this motor have run the mileage up to 80 or 90K with no troubles. My TR-6 engine made 150K before showing signs of ring/valve guide wear. If I don't have to tear the motor apart, I can definitely use the money for other restoration parts. Plus, I'm thinking along the lines of "If it isn't broken, don't mess with it!!" Thanks in advance for your insights,
