Tabcon
Many of you saw the photo's of the TR4 I got recently. If you did, you could see that the car was restored and looked really good. While the restoration was an "amateur" one, it was pretty good nonetheless. In a sense, I'd rather have a car that was restored by someone who once loved it than by some $40 an hour shop.
The one thing I've found with my car is that the previous owner paid a little more attention to aesthetics than to the actual mechanics. I'm not sure if he was running out of money, I mean who's ever had that problem, or he just didn't know.
Anyway, what started out as a simple attempt at detailing the rear wheel arches, suspension and chassis has turned into a major overhaul. A restoration of a restoration I suppose.
Today, I completed the entire removal of every little bit of suspension and brakes, as well as the rear axle assembly. I sorted everything into piles and started cleaning and painting all the components I'm going to reuse. Who knows what this will lead to.
I've decided to upgrade almost everything to bring it all up to modern standards while still retaining the authenticity, at least as much as possible.
The PO installed either original parts he cleaned and sometimes sandblasted (a lot) and then painted, or cheap after market stuff. Some of the parts had a good deal of metal removed and were beginning to rust again. Every nut, bolt, washer and lock washer were corroding and or rusting also. He also used fairly cheap hardware, some of which doesn't look like it was rated for the task. It may not be "original equipment" entirely, but I'm going back with all high grade zinc plated fasteners. If I'm going to drive this car the way it was meant to be driven, I at least want the piece of mind of knowing what's holding everything together.
If anyone is interested, I'm going to catalog the restoration of the restoration with photos on my TR website. Before and after type stuff. I haven't actually taken any shots yet, but I'll most likely start tomorrow and have them up by tomorrow evening. The car actually looks sort of funny sitting up on jack stands with no wheels or suspension under it.
I've been doing a good bit of research on all the brake and suspension components and have compiled a fairly good list of what I intend to use. Spring rates, braking, caster, camber...blah, blah, blah. Hopefully, when it's all in place, it will handle and ride a bit better.
Oh yea, tomorrow I'm going to pull the steering rack also. I want to replace it with a quick rack, but I'm not too sure about the quality of these after market ones.
Fun!
Fun!
