terriphill
Here's an update. As many of you know we have been frustrating over how terrible the B is running now that we finally got it started. It bucks and farts and smokes....arrrgh.
Tony pointed us towards the side plate,which was full of crud, we cleaned it..no real difference. (Although this is probably where the problems began)
It acted like it was missing. We removed the carb to make sure it wasn't gunked up. Checked the timing, dizzy on and on. When we pulled the plug wires with it running, it dropped significantly with the first two, but the back two plugs were obviously not getting spark. We had pretty much decided it was the distributor because we just weren't getting fire to the back two cylinders. Dave stepped in and suggested we buy new plugs before we replace the distributor and guess what? It purrrrrrrs. Lots of power, no shimmies, no shakes.
Then it died...oops, forgot to reconnect the fuel pump which we had disconnected to check for spark. Woo-hoo! Running again...then it died.
Putting our best thinking caps on, we decided to think like a BCFer..simple first...is it out of gas? Guess what...it was. This evening it's running smooth and strong!
Thank you all for your help and input! Hopefully the next post will be pictures of our first trip around the block.
