What? From memory, on both pin and slot drives I remember there was tons of axial travel available at the pump end. I remember the end float control being a function of the clearance between the front retaining plate, pulley, and cam boss. Again from memory, aren't you supposed to replace the front retaining plate if the endfloat isn't between 0.003/0.006 ?
