I just installed a new rocker arm assembly. Previous to that, my pressure was below 20lbs at idle, and the oil geysered from the rocker arms. After installing the new one...actually re-built by Rocker Arm Specialists...very well done and came recommended. The oil is no longer geysering and the pressure held at 22lbs at idle...for a while. It has now dipped below 20...15-18lbs. What else could be causing the pressure drop?
Could it be the oil pump? Any ideas or suggestions would be welcome.
Don
Don
