LAW75
Hi there fellow travelers. Have a question re my AH 3000 Mk III BJ8 Phase 2 oil pressure. Just had all the gaskets (ALL) replaced, including the relevant oil seals. My best recollection is prior to this, my oil pressure was about 15 at idle and 50-55 when warm and at about 40mph+. Now my pressure is at 15ish at idle and only 40 at 40mph+. The mechanic that replaced all the gaskets and oil seals said that the "40" oil pressure read is "not a big issue" and should not harm the engine nor effect performance. I know the books say the pressure at warm and accelerating speeds should be about 55ish. Is there any agreement with the mechanic? Or should I have concern?
PS. 1. I have an after market oil filter, 2. Checked oil level, 3. using "correct" oil weight, 4. no leaks of any concern, 5. car was restored about 10K miles ago.
Any insight, suggestions or directions would be greatly appreciated.
Thanks
Thanks
