OIL PRESSURE RELEIF SPRING
BOBBYR
Hi Guys,
Last night, I received two oil pressure springs in the mail, from Moss. I was wondering if anybody knows what the proper length of the spring is suppose to be.My healey is a 1965 with a 2912cc. As always, I appreciate your help.
Bobby R
Hi Bobby,
The shop manual says;
2.687 inches
Number of coils= 13
Diameter= .484 inches
I ordered a new one from Moss earlier this year but
did not install it because it was substantially shorter than
the factory spec.. I think it was around 2.4 or 2.5 inches long with the 13 coils.
My original spring was compressed and had apparently lost some of it's original temper, if it ever had any. I lengthened it to the spec of the shop manual and then installed it. I pulled it back out and checked the length again and found it it had compressed back to the exact same shorter length that I had started with. I guess it had developed a " memory " at the shorter length.
I took it back out again and this time stretched it 2.9 inches long, reinstalled it , pulled it back out to check it a 2nd time and to my amazement, it was now 2.68 inches long. The spring apparently had a " memory " of the original length of 2.687 inches as well as the shorter length.
Since It seemed to be staying at the correct length this time and my oil pressure improved 5 or 10 lbs or so I left the original spring installed and if I ever see lower oil pressure again, I will check the length on the spring again. If it ever goes back to the shorter length, I'll stretch the new Moss spring to the correct length and then try my hand at heat treating the spring to see if I can get it to stay at the correct length. So far the oil pressure is staying the same as after I stretched the original spring back to the correct length so I have left it alone.
Ed
Hi Ed,
Thank you for your response.I had ordered two springs off of moss, earlier in the year and they must have been on back order. Anyway, the other day ,they sent me the springs and I just wanted to check on that measurement before installing. I hope everything is good with you and thanks again.
Bobby R
Hi Bobby,
They were on back order ?
Perhaps they purged stock after someone else told them about the springs being shorter than the spec in the shop manual ?
Can you post the overall length of the new springs ?
I wonder if they are now the correct length ?
Thanks,
Ed
Hi Ed,
As soon as I emailed you last night, I went to the garage to measure the springs.You were right and they are 2 1/2 inches in length.Like I said, it took me a long time to get these.If you run into a hard time getting one, let me know where I can send you one.Thanks for your help.
Bobby R
