Fire it up to go to work and she starts fine. The OP creeps up to about 45 psi and then dips to 20 and I hear a slight ticking. (Never did this before - oil changed last summer and only driven about 200-300 miles) She idles and the OP increases. back to 45-50. I start to drive. OP is a steady 50 at speed. Stop at a light OP dips to about 48. Put it in gear and take off. OP drops to 20 and almost to 0 but springs back up to 50. Ticking stopped after about 10 seconds.
What gives? Not sure if this is normal for these cars or not so I post to make sure.
If my Oil pump is going, what does the swap entail? Engine pull?
Hi Guest!
